there’s actually another mystery (metal) pushbutton on the dash,
between the ammeter and fuel guage, in a symmetrical position from the
(black bakelite) starter button…
http://tinyurl.com/neaxqq
(that’s not even my car, it’s a picture from a collection of interior
shots I have, and it’s in many many of them, although in several there
isn’t one)
it’s also shown in the drawings of the owner’s manual (one of the two
drawings actually, the first one doesn’t have it) but there’s no
explanation anywhere… and since I did remove the central wood, I know
mine is not even connected…
I’ve seen it in a lot of photos of other MkVII’s, does anyone know
why it’s there??
ciao & thanks again
diego
Torna a grande richiesta l’offerta estiva di Tiscali Photo !! Non rinuniciare ai tuoi ricordi. Stampa le tue foto a soli 0,09 eurohttp://photo.tiscali.it
[Commercial use of subscribers e-mail addresses prohibited.]==============================
That button is for operating the windscreen washers. Apparently your Jag
is so equipped.
Alan
51MKVII
diego.montefusco@tiscali.it wrote:
hi again,
isn’t one)
Dick Hile------Original Message------
Sender: owner-saloons@jag-lovers.org
To: SaloonJag
ReplyTo: saloons@jag-lovers.org
Subject: [Saloon-lovers] another mystery button in my MkVII
Sent: Aug 16, 2009 2:57 PM
hi again,
isn’t one)
why it’s there??
ciao & thanks again
diego
My car is equipped with windscreen washers and it has the
button. The windscreen is cleaned and wrapped up; stored in
the loft. The new windscreen rubber is in a box on a shelf.
The washer bottle is on top of the parts storage bin. And I
have been using the battery from my '64 Riviera when I want
to run the car. No test today.
Bernie–
Apparently your Jag is so equipped.
ah, okay… thanks a lot! I wonder why the manual doesn’t
mention it…
also, how is the windscreen washer operated on the MkVII which do NOT
have that button? I’ve seen quite a number of pics of dashes without
it…
anyone here with an older MkVII who can tell me? I’m just curious
thanks and ciao!
diego
In reply to a message from Dick Hile sent Mon 17 Aug 2009:
Diego,
I have a MK-VIII (MK-8) Operating Handbook and it shows that second
mystery switch as being a ‘‘Fuel Changeover Switch’’. Yes, it’s not a
MK-7 but the dash looks identical to yours with the switches and
gauges in the same places.
The Operating Instructions for the switch say to ‘‘rotate switch
clockwise for Right Tank, anti-clockwise for Right Tank’’.
Zurdo–
Maybe it was an option and some cars didn’t have washers? Just a guess.
Dick Hile
second mystery switch as being a ‘‘Fuel Changeover Switch’’.
Yes, it’s not a
and gauges in the same places.
indeed they are.
but the switch I was talking about is a small metal push-button ABOVE the
bigger, “turnable”, bakelite fuel change-over switch!
ciao
diego
In reply to a message from diego.montefusco@tiscali.it sent Mon 17 Aug 2009:
In the older cars, the chrome windscreen washer button was
located under the wooden ‘‘projection’’ in the middle of the
dashboard, almost invisible. You had to press it upwards
when you wanted to clean the windscreen.
My 1953 MKVII has the button I believe you were asking about, and indeed it
is a Windshield washer “button”. Pushing it
creates a small amt of air pressure that that activates the washer system.
If you look at back side of the “button” it should have a
hose attached that goes to the washer bottle. It may have been an option and
not all cars were equiped with it.
Gene Johnston
'53 MKVII
'86 SIII
'94 XJ40
'04 S typeSubject: RE: [Saloon-lovers] another mystery button in my MkVII
To remove yourself from this list, go to Jag-lovers Forums - Jag-lovers
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.392 / Virus Database: 270.13.58/2309 - Release Date: 08/17/09
06:08:00
My VERY early MK VII did not have washers when built.
I went to the trouble of fitting some of the correctish Trico
sort, and in 16 years have never needed to use them.–
it…
In support of the suggestion that the washer system was an option:
My MKVII is also an early product “Manufactured 14th September 1951”
Chassis #731229. As far as I know the dash is original and has a empty
hole where that windscreen washer button should be. There are no spray
nozzles installed on the cowl. I have not gone through the effort of
installing the system since it was originally without.
Alan Schultz
51MKVII
In reply to a message from Diego Montefusco sent Mon 17 Aug 2009:
It may be used to display crankcase oil level on the fuel gauge. I
had a Mark VII back in the 1960’s that had this feature, I believe,
using a crankcase-mounted sending unit.–
According to the Spare Parts Catalogue, Mark VII cars had windshield washers beginning with chassis numbers 714467 and 734708.
So cars from 710001 to 714466 and 730001 to 734707 did not have them, in other words the first 9173 cars.
This was announced in Service Bulletin 115 dated December 1952.
It seems to be standard equipment, not an option. It mentions a chrome plated control button.
XK120 also received washers at this time.
BTW there is a discrepancy between the SB and the SPC on the beginning RHD chassis number, the SB giving it as 713467 (plus 346-349).
Were these electric windshield washers with the dash button? I recall an Opel Kadett I had many years ago that had a squeeze bulb on the floor one would press with their foot to activate the washers. Quite ingenious.
No, the windscreen washers used vacuum to operate the pump and spray fluid. When you pushed the button the dash it applied vacuum to the fluid pump. They were electrically operated.
