As a temporary fix and frowned on by several veteran
contributors I offer up the part number and size for a spare
freeze plug in case you get into a bind in the middle of no
where. The Dorman part number is 02603 and it is 1 1/2 to 1
5/8 inch which equals 38 to 41 mm in diameter. The packing
is usually in the self help fix it area of your local parts
store in a yellow and blue package. The goes much further
into the engine block than than factory steel or commonly
used copper expansion plugs. It will actually begin to turn
once it is tight in the block. It must be installed dry to
get a good fit and expand into the crevices of the block
hole. I also changed my t-stat cap to 7 psi and I am running
normal temps after about 20 miles of testing. Water level in
the radiator is stable and the plug is not leaking at all. I
have a spare on hand just in case which will go into the
tool box in the boot.
I think with a 1/2 inch and 7/16 inch spanner on hand for
the headers and downpipes I might be able to change a blown
plug in the field after a reasonable cool down of the engine.
Gerard
Loveland, CO
3.8 MK2 MOD 1966–
The Jag Man
