Have just got my 1960 BRG Mk2 back from the shop after having a XK
3.8L engine fitted. Now, the engine # put in is 7B615***: which I
believe is actually a 3.8L engine from an S-type?
Now, these engines were built in the day of leaded petrol, to
protect the valve seats etc. Given we no longer have leaded petrol,
do I need to put lead-replacement additive in the fuel?
I have been told several stories:
It can’t hurt.
it will deposit on the piston head and cause pre-ignition
it doesn’t need it because the cylinder head was manufactured
with hardened seats.
I have plenty of additive (kindly given to me by a friend with a
Valiant Charger (Aust) whose engine was modified to hardened
seats) - however, I’m not sure whether I should be putting additive
in my fuel tank.
Any help/assistance appreciated.–
jag060
In reply to a message from jag060 sent Mon 1 Jun 2015:
jag060,
This has been discussed many times and can be found in the
archives. It doesn’t need it.
Paul–
Daniel,
As Paul says, you don’t need a lead additive. Dry Fuel, or
similar… now that is worth putting in the tank, at least at the
end of the season before the layup.
Andrew–
in my fuel tank.
