Thanks for the advice. The panel is off and I have tired assisting it to no
avail. I also tried a long thin screwdriver, but I cannot get it aligned
with the screw post. Would it help things if I removed the mounting ‘box’ at
the bottom?
Chris Stephenson
cs@tscg.net
(404) 915-7669-----Original Message-----
From: owner-saloons@jag-lovers.org [mailto:owner-saloons@jag-lovers.org]On
Behalf Of bjorn.lindseth@borregaard.com
Sent: Monday, November 06, 2000 8:54 AM
To: saloons@jag-lovers.org
Subject: RE: [Saloon-lovers] Help - Window is stuck down - 420G
Hi
I have had this problem with one of my windows on my 420G. The passenger
side window used to get stuck in down position. I usually got it up by
open up the inside door panel and nock on the mechanism with the back of a
screwdriver. Sounds to easy , but it worked for me. Last summer i took
the hole mechanism out and cleaned it, greased it and put it back. Haven’t
had any problems since. I have the original tool to manually wind the
window up, but i find it difficult to use it. If you manage to align it,
it takes a lot of turns to get the window up. It is also possible to use a
long thin flat screwdriver.
Bjorn Lindseth
1969 420 G
Fax to:
Chris,
In the trunk there should be a long handle that look a lot like a lug
wrench
except that it has a screwdriver tip on the end. This goes into the door on
the underside and will allow you to roll the window up manually. The tool
should be mounted via clips on the right side of the trunk, under the tool
box and behind the spare tire. Attached is a link to the page from the
parts
manual of the tools kit. Number 21 is the tool you’re looking for. Happy
hunting!
Bob Powell
Senior Programmer
Brandywine Electronics, Ltd
34 Blevins Dr., Suite 10
New Castle, DE 19720
800.924.9992 ext 106
302.324.9992 ext 106
302.324.8611 fax
www.bel.com
[mailto:owner-saloons@jag-lovers.org]On Behalf Of Chris Stephenson
Sent: Friday, November 03, 2000 5:38 PM
To: Jaguar
Subject: [Saloon-lovers] Help - Window is stuck down - 420G
Hi Guys and Gals,
I finally got my 420G to the point that I felt good about having passengers
ride with me. I fitted a new exhaust, fixed my headers (thanks to the
group)
and completed various other tasks. Now, my drivers (left) side window is
stuck down. It is not the switch because I bypassed it. I can hear the
motor
click, but it will not turn. I hope it is just binding. If I could just get
it up I will be OK as winter is approaching. However, I do not know how to
do this. I see in my manual that a special tool is needed. Do any of you
know of anything else I can use in place of this tool. Is the bottom of the
winding screw slotted, or does it accept a socket or allen wrench?
Chris Stephenson
cs@tscg.net
(404) 915-7669
