[Saloon-lovers] Middle Mufflers 65 MK X 4.2L
Redoing the exhaust system on my 65 MK10 with the 4.2
engine.I needing dimensions of the middle mufflers. Are they
oval or round? Is the inlet & out let inline or offset? What
is there length,width & height? Thanks for any information–
code621
Carlsbad New Mexico, United States
In reply to a message from code621 sent Fri 6 Nov 2015:
The Parts Manual gives an excellent pic.
Mine are non-standard, so cant help with measurements
Presume you are talking the ones just in front of IRS
They are oval, offset front inlet pipe.
NOTE; the rear outlet is offset and curves to join the IRS
thru pipe…it is CRITICAL this be perfect, or will interfere
with brake disc, or half-shaft…or both!
My expert pro exhaust specialist did not wish to attempt to
fabricate one, due to the difficulty.
2 options;
  • Bell SS exhaust
*It is possible to custom fabricate pipes that run under the
IRS.
I have been told never delete these middle mufflers, mine
has the slim very rears replaced by straight thru SS pipe,
its a bit noisy on the highway, but has a very sports car note–
Tony
I can measure and send you a photo of a new one, but it is
at my summer house, where I will go either this week, or
next. Please remind me in due course.
Peder–
peder
In reply to a message from peder sent Sat 7 Nov 2015:
That would be great.The rear half of the exhaust system was
cobbled together.The tale pipes were rubbing on the brake
system and other parts.Made a mess.Thanks for taking the
time to provide me the dimensions and the photo.–
code621
In reply to a message from code621 sent Sat 7 Nov 2015:
This guy has made the exhaust-style I mentioned, under IRS
cage, not thru…on a 420G, see pictures.
He also has no rearmost slim silencers, but custom pipes
Big wheels as well!
http://www.jaguarmk10420gsymposium.com/t719-road-wheel-fitments--
Tony
