Can anyone tell me if the front and back windscreen from an S-
type fit a MK2? I think the front would be close if not the same
but the back different.
According to Barratt’s catalog they are all the same.
Mike Eck
New Jersey, USA www.jaguarclock.com
'51 XK120 OTS, '62 3.8 MK2 MOD, '72 SIII E-Type 2+2
Thanks,
Neil
[Commercial use of subscribers e-mail addresses prohibited.]==============================
Thanks,
Neil
Neil. (Mk2 1967 2.4L O/D)
Warrington, United Kingdom
In reply to a message from Mike Eck sent Tue 1 Mar 2005:
I thought I had read somewhere (Taylor?) that the
fronts are the same, but the rears are different, so I
checked the parts lists.
According to the parts listd the fronts are identical,
but the rears are two different sets of part nos… in one
case, only one single digit apart strangely.
front (identical)
bd.28586
bd.29575
bd.29575/1
bd.29575/2
perhaps that is why it looks so great! I could imagine that
the shape might be the same, but the thickness different.
Andrew–
Mk2, S-type and 420 share the same front screen. Mk2 is unique, S-type and
420 share the same rear glass.
Alan----- Original Message -----
To: saloons@jag-lovers.org
Sent: Tuesday, March 01, 2005 11:00 AM
Subject: Re: [Saloon-lovers] mk2 front / back windscreen
front (identical)
bd.28586
bd.29575
bd.29575/1
bd.29575/2
Andrew
In reply to a message from Alan Pennykid sent Tue 1 Mar 2005:
I have a whole set of sundym S type glasses. I plan to fit them on
my MK II. I guess it will fit with no problem apart from the rear
screen. Is it possible to get a sundym rearscreen for MK IIs
somewhere? If not, is it possible to re-cut the S Type rear screen
to fit a MK II, or is the shape different?–
Gael
If the rear glass is one of the heated ones it is also laminated and it’s
possible to cut it(but dont epect the heating element to work again), not
sure how the shape would match the Mk2 Roof. If made from
Toughened/Tempered glass as most would be, you can’t cut it, it will simply
shatter if you try.
Sent: Tuesday, March 01, 2005 9:59 PM
The only glass that will fit is the front windscreen. All sideglass of the
Mk2 is defferent from the S/420 glass, as well as the rear screen.
It becomes quite clear if you park the cars side by side: the top curve of
the side glass on the S/420 is much straighter than the Mk2.
Jack Verschuur.
Gael
d
