[Saloon-lovers] Mk2 starter motor wiring question
Hi everyone,
Have my '62 Mk2 project started and while I have the engine
out for the gearbox swap and other maintenance activities I
plan on refreshing and possibly upgrading some of the aged
wiring in the engine bay. My car is wired so that the
starter motor will engage and turn over the engine even
with the ignition in off position. Is this standard wiring
procedure on these cars? I’ve looked at the wiring diagram
in the service manual but cannot tell whether this is
correct.
Thanks,
Tom Phelps–
Seattle, WA
In reply to a message from tapped sent Sun 22 May 2016:
Tom,
The start button on the dash should only operate the starter
if the ignition switch is ‘‘On’’, but the button on the solenoid
will turn the engine regardless of the position of the ignition
switch.
Andrew–
1968 3.8S
Zurich, Switzerland
Hi Tom,
it turns over, but without ignition. You can crank the
engine with the push button in the engine bay underneath the
metal cover near the scuttle.
Best regards
Lindi–
lindi
In reply to a message from lindi sent Sun 22 May 2016:
Thanks, Andrew and Lindi. I suspected mine was wired
incorrectly. Will have a look at how it’s wired at the
ignition switch.
Tom–
Seattle, WA
starter button on my car will turn the engine over without
the ignition on and I’m not aware of any alterations made to
achieve this.–
John & Tigger (3.4 Mk 2 Auto 1966)
Neston, Cheshire., United Kingdom
It is not supposed to do that. The white wire on the starter push was
originally connected to the ignition switch.
Mike Eck
New Jersey, USA
www.jaguarclock.com
'51 XK120 OTS, '62 3.8 MK2 MOD, '72 SIII E-Type 2+2
achieve this.
[Commercial use of subscribers e-mail addresses prohibited.]==============================
In reply to a message from Mike Eck sent Thu 26 May 2016:
Thanks Mike,
I didn’t doubt you but did check the wiring diagram and you
are quite right; never made sense to me to be able to turn
over without ignition on but I presumed this was the way it
was meant to be. I will not change it now; after 16 years of
usually happy driving best left well alone. Curious how two
cars have been altered in this way though.
Cheers–
