Thanks Lee. Using teflon tape sounds like a good idea (although the
material used was quite britle when I peeled it off). I assume the
teflon tape will take the heat developing in this region?
Per-Age>Date: Mon, 11 Sep 2000 22:30:57 -0500
Subject: RE: [Saloon-lovers] Head offPer-Age,
Sounds like someone used Teflon tape on the threads. You can usually find
it in places that sell plumbing supplies and pipe fittings, etc. Unless
they wound it all the way down the head stud, though, it would only protect
the threaded area. Most of the time, the problem with head removal is caused
by corrosion between the steel stud and the aluminum head, not the threaded
area. When the aluminum corrodes due to being in contact with the steel and
a little moisture, the corrosion expands and essentially locks the head to
the stud. Coat the studs with anti-seize compound, or grease, and you’ll
probably keep the moisture out enough to eliminate the corrosion problem.Regards,
Lee Scott
Shelby, AL
oldjags@bellsouth.net
'67 420
'71 Series 2 OTS
http://personal.bhm.bellsouth.net/~shelsoft
Per-Age Krogstad
Stjordal, Norway
1954 MG TF
1954 Jaguar MkVII
