Darrell,
Please take a digital picture of the Spin-On oil filter adapter and post
it on Jag-Lovers. That way others can see what kind of adapter you have
and offer suggestions. There are aftermarket adapter units that can use a
wide variety of filters, but not necessarily the same ones. In addition
some have taken spin on oil filter assemblies from later version XK engine
and modified their engines with these. In that case OEM filters, or
suitable substitutes, are what’s needed. It would also be helpful to know
what the diameter of the threaded portion of the adapter is that the filter
screws onto and the outer and inner diameters of the base surface where the
seal on the filter surface presses up against when the filter is tightened
down into place.
Paul M. Novak
1990 XJ-S Classic Collection convertible
1984 XJ6 Vanden Plas
1969 E-Type Fixed Head Coupe
1957 MK VIII Saloon
Ramona, CA
@Paul_M_Novak1----- Original Message -----
To: saloons@jag-lovers.org
Sent: Sunday, April 23, 2006 5:11 AM
Subject: Re: [Saloon-lovers] Spin-On oil filter {Scanned}
In reply to a message from Louie sent Wed 19 Apr 2006:
The adapter was on the car when I bought it, so I don’t know what
it might be.thanks.
Did you use the adapter off the S1 XJ6 ?
Louie
Pronk
