I’m just about to replace the rear screen rubber on my series 1 because the old one is brittle, broken in parts and wont hold the chrome trim. The jaguar service manual on page N10 shows two tools labelled Churchill tools JD23. Are they needed and are they or equivalents available anywhere?
the seal goes on the metal lip, then the glass goes in the rubber
I have done it and observed it done on 420G, other Jags & vehicles, with a thin strong cord, and/or special tools for windscreens made of hard plastic.
its not always easy, and an assistant is desirable
careful with the rear screen they can break in a trice if treated wrong, not laminated
I got my windscreen tools of a pro for a few $, and you can purchase them
I dont like the idea of metal edged tools on glass
Well I got the glass out ok and fitted new seal into the frame and the glass into the seal but can’t for the life of me get the locking rubber strip into the seal. It seems the tool B is a real necessity, anyone know where I can get one? Other option would be to leave out the locking strip, is the glass likely to fly out if I do that? It seems to me if I can get the chrome finishers in they would have the same effect as the locking strip.
Any advice?
Thanks for the info Tony, I tried to insert the rubber using a tool I made from stiff wire but without success. It is the only strip sold by SNG Barrett but I’ll look for a smaller section piece elsewhere. The shape is virtually a quadrant with slight lips. Its a bit cold here still but next week should be warmer, I’ll try again then under the influence of a bit of sun and fairy liquid or rubber grease and see if I can get any further with it.
I see what you mean about the chrome strip as well. Even the one from the XJ6 seems too big for the moulding though it was inserted in tho old one ok before I took it off. I;m beginning to regret starting this job but the old rubber was very badly cracked and at lease it did show me that there is no rust under the trim.
I replaced the rear rubber several years ago without the special tool. I recall it to be a challenge but doable. I would wait for the warmer weather. The loan of a heated garage with a heating source preheating the metal and rubber gasket overnight might help.
Maybe a hair dryer in the hands of a second person directed at the rubber as the installation proceeds would make the rubber more pliable.
Also, a liquid, not sure what, applied to the rubber insert might help.
their is a tool with a grooved wheel that is correct for the job, available at hardware stores for fitting the locking strip on screen wire doors & windows etc, needs to be sturdy though.
grind an old screwdriver tip to a smooth grooved end.
needs a bit of force, be careful, you do need a locking strip in there
Thanks for the further advice, I’ve ordered a tool, a spreader with a roller behind to try to get the job done. I spent yesterday trying with a home made tool and managed about 2 feet with very painful hands but have now reached a bend where the channel closes up to almost nothing so will wait on the tool before proceeding. Heat helped a bit.
Well its in and looking good, next are the chrome strips which also look like a PITA to install. Any good tips on that one i.e where to start and how to lift the rubber over?
The new gasket came from SNG and I’m hoping the srtips will be the right width for the slots they fit into.
Ian
Hi Ian, I’m am also now in the process of fitting the chrome inserts to my front and rear screens. Do you have any tips on doing this as mine are also new seals and it’s looking like it’s going to be a tough job. Thanks
George
Do a search on this site " Series 1 screen install" in the XJ category. Sorry, I do not know how to link it. Use the magnifying glass icon at the top, next to your avatar. If you have the correct rubbers and spreader, there should be no issues. At a pinch, you can push the spreader in with a wide flat blade screwdriver, but there’s a strong likelihood of slipping and damaging either self or paint. Ditto, chrome trim, small flatblade screwdriver.
Be aware that for some models, the reproduction rubber seal does not always have the grooves spaced correctly for the chrome width.
In the case of my 420G, I inserted one chrome edge in the groove, and used spaced out blobs of urethane to adhere it on, with softer black filler to fill in any gaps
It looks good at any distance, even the closest examination, and has lasted perfectly for years. It does sit slightly higher on the rubber profile, but I had no choice
Thats just in case you have this issue, think I have heard of XJ guys having the same trouble I did
Thanks for the replies.
Unfortunately doing a search I can’t find much information of anyone that’s done this with much detail.
Looking at it so far the only option I can see is to do as mentioned which is insert one side and stick the other side down, although I really would like to get it how it should be
