Hi all,
Anyone know where I can find a functioning used headlamp control module for my 92? I’ve tried rsoldering it a few times and it’s just not working out… at one point I had it functioning when the car was running but now it’s back to providing high beams only at all times, which of course drains the battery when parked.
If there is any chance it’s the same for a 94, PM me the part no.
There are about 50 relays, a half a dozen ECUs and a bunch of modules in my parts bins.
This hella relay is rectangular, the size of two standard relays side by side. In a metal case. It has an internal physical toggle between two outputs.
I have no idea if the 92 uses this or not. Only old jags here.
It’s not just for high beams. The module for headlight control is DAC6902 and would be the same from 92 on. It’s a six pin box on the drivers side inner fender.
