I have a broken seat release cable on the driver side seat in my 94 XJS 2+2. Can it be accessed by removing the molded plastic frame that runs across the top and down both sides of the seat? I assume that the release knob simply pulls off in order to remove the plastic piece that makes the “pocket” the release sits in? Doesn’t look to be a huge job, but I don’t want to make it worse!
Yes, the knob just pulls off.
After that you are on your own.
I never needed to go any further.
Ok, thanks. Every little bit helps!
