What’s the preferred thermostat for the 4.2 series 1. Had a series 2 thermostat and that is not a good solution.
I got mine from SNG and it has worked flawlessly. Call and ask for Will or Tony and they will get you fixed up.
–Drew
Yes I did read that article.
Either use the sng part. Or convert to a series 2 thermostat housing.
Does the sng thermostat work well enough
The SNG thermostat is as close as you will find. There are no perfect solutions.
Do the S1/2/3XJ6 thermostat housings fit the earlier manifold? If so, I have a few spares.
Have a sng thermostat on back order
It’s going to work better then the s2 thermostat I’m sure
Post some photos of the XJ6 housings, I don’t have any of them available.
The S2 thermostat will be the best working solution, but you’d be adding a visual element to an engine bay many regard as art.
Soon as I find them, under the snow, I’ll get on that…
Hi, a few years back I found on Ebay a NOS thermostat in the original box with the correct Jag part number. This fall I changed the coolant and thought why not install the original thermostat…it does work better. Once opened, the bypass allows most of the coolant to pass through the radiator and I noticed that the cars temp doesn’t creep up so fast at rest. My 65 OTS is happy.
Allen
