Thank you Frank.
Think you’re confused…or I am??
The “motor” you seem to have thought i was mentioning was the old generator type gizmo run on the end of the cam on earlier cars mentioned (?) I did’t believe there was any motor within the tacho…
Tach never worked since I’ve owned the car and it was received in this state (S3 motor).
However, remember, this is a Series 1 car. no ignition “amp” as on the S3 and FI cars, etc…if that is what you were referring to?
Other than motor(engine), otherwise all original Series 1. Carbs, transmission, etc…Mistakenly I believed tach ran off of transmission which is why I mentioned it above, that’s the speedo I was thinning of…it’s late!
Earlier cars I’ve had (E Type and Mk2) had this generator gizmo on end of cam which ran the tach).
Don’t know if Series 1 XJ6 did as well…
Mentioned S3 motor(engine) only because it does not have cam machining at rear end as the original S1 motor should the tach have originally run from there using the little gear generator as on earlier models as stated…the S3 XJ6 cam cover is flat in the back…if that makes a difference with the old tachs that ran there…I can’t remember anymore.
So, does the original S1 tach run off the neg terminal coil terminal as well like the XJ6 per that post?
EDIT:
Solved and important. The S1 Tach does NOT go to the Negative Coil connection like the S3 apparently…
Per a past post found and responded to by no other than YOU Mr. Frank.
Found within some Post entitled “Loose Wires and Mystery Relay” (?!)I came across this:
Hold it, Steven - and procede carfully, very carefully…
On the SIs the coil pos goes through the tacho, for some obscure reason.
This means the tacho wire is live, and conncting it to coil neg will
effectively ground it - and zap…
If you cannot discern wire colour disconnect it from the coil, measure
voltage - then turn on ignition and remeasure. If it has 12V at any
time; do NOT(!) connect it to coil neg…
Point here being; the wire on the ‘other side’ of the resistor should be
from the tacho, and carry 12V with ignition ‘on’. The resistor should be
checked by disconnecting all wires and measuring resistance in it -
likely some 1 - 3 ohms. Break or contiuity is a defective resistor - and
may be one reason for PO wire machinations…
