Can anyone tell me where i find fhe main live wire that powers everything is as mine has had the whole battery wiring removed so can anyone help me out
You need a service manual, but to get you started:
The battery positive terminal, starter solenoid, alternator output, and two large insulated studs are all connected together with heavy gauge wire. The studs are located on either side of the bulkhead; each should have other wires connected as well.
Hi Harry, let me know if you could use some pictures. Paul
Yes pics would be great with all the wiring lines and where they are ment to be
Yep. Tomas and Rosanne will be in Gosford on Saturday - he has a rep game on Sunday
Can you put up pics of the wiring all round but atleast on the fire wall as we have 3 wires that look as if they go to somthing but we dont know what as there nothing there
Here’s a wiring harness diagram
along the bulkhead / firewall there’s an 8 gauge wire that runs the width of the car The positive post of the battery connects to. on the other side of the car you’ll see a identical post where the main feed from the alternator is connected to.
