Hazard lights are not working…where is the relay and the fuse on a 1973 XJ6?
Does the direction indicators work, Fred - they use the same relay…?
‘…behind and to the right of the steering column’ the good book says about the relay…
Frank
xj6 85 Sov Europe 9UK/NZ)
Yes the turn signals work fine…I understood there is separate relays in the Series 1 cars… I’ll do some exploring today… thank you
Ok the Series 1 does have a separate hazard flasher located just to the right of the turn signal flasher…under the driver side dash next to the steering column. That was the problem I was having…bad connection/faulty flasher.
