HI
I am working on a 76 series 2 xj6 with carbs and pumps in the fuel tanks. I am having an electrical issue as the components are working.
What i need is a wiring diagram for this specific model. The series 3’s are different and of course the FI ones are different. Does anyone have a wiring diagram for the power supply to the fuel system pumps and switches for this car
Pumps are operated via a fuel safety relay. Which ensures that fuel pumps only run in ‘crank’ - or with the engine running in ign ‘on’. A crucial item is an extra oil pressure switch on the engine. ‘Break’, no relay action with engine stationary (no oil pressure) - but switch bypassed in ‘crank’ to activate relay. If switch fails to ‘make’ with the engine running will stop the fuel pumps…
Well I did a brake job and then the car quit running.
I had to replace the booster and when I did I pulled the booster and pedal assembly from the car. I suspect that i pulled a wire when I did this. I of course can’t see a loose wire.
I am not getting power to the internal fuel pump, the rollover switch or the tank switching switch. I don’t think series 2’s run a relay for this, though they should.
So basically I am trying to figure out where they get their initial power and where does it run to
Your combination of symptoms is not related to the fuel safety relay alone, Kevin - so your ‘torn wire’ theory has merit…
The fuel pumps are powered from the ign key, white wire to the fuel safety relay. With a white/red from the starter solenoid relay to override the safety relay in ‘crank’.
As an extra safety; the white wire from the safety relay goes through the inertia switch ( is that your ‘rollover switch’?) to the changeover switch - then to the pumps. If the inertia switch was tripped by your working, it will stop the pumps - so the inertia switch should have power both ‘in’ and ‘out’…
If there is no power ‘in’ to the inertia switch (are there two wires connected to it?) - you may backtrack the white wire to locate a break, or loose end?
However, the white circuit is general power to all engine management systems, including coil. Have you checked that there is power to the coil ‘+’ - in case you have torn a wire from the ign switch?
The wiring diagrams do not show the actual routing of the wires. The only clue as to ‘where’ to look for a break.is loss of power between components listed. And hopefully you have the components listed…
