I have learned the hard way not to trust what the previous owners did to this car. Can anyone confirm the correct license plate light lens orientation? See photo, I suspect it might be backwards but that’s where the holes were…
In my case I found there was only one way to put it back together. There are screw holes in the 2 short sides, and these holes are off set from the centre on both the car and the light components. Mounting the light fixture was then only possible in one configuration.I inadvertentley tried one assembly of the light before i realized the off set hole on the light frame and lens did not match up.
Thanks, my bad, I flipped the lens over and it fits Properly.
So the triangular, in cross section, “dome” goes up into the light fixture?
