I appreciate your inputs. I am new to this engine, though I actually WANTED it so I could learn more about it’s design and maintenance. I like engines. My airplane has a 1340 C.I 700 HP radial. I have spent 20 years learning about it and it’s maintenance.
I did not think this model ( V-12 Series III) was particularly prone to overheating (I had a series one about 40 years ago that had some issues that I solved well enough to use as my driver.) I have been frustrated with the issue as it was unexpected. I thought I was going to be fiddling with Carburetors and ignition stuff. So far, only issue I am dealing with is the cooling. If I can’t solve this, I can’t drive it anywhere.
The car IS equipped with airconditioning and the Evap is very large, right in front of the radiator. However…I have the new Aluminum Radiator and double high output fans that are keeping the temp in the radiator rather low so I am not ready to tear out the air conditioning junk.,…… yet. I will finish the heater system flush and check out to further eliminate it as issue. I AM concerned that there is air in the system at this high point that is hard to “burp” out. I was thinking of adding a valve for this at the top of the heater.
Clearly the heat is building in the rear of the Heads as the temp differential from rear to front is about 15 degrees when the heat takes off. I have shut down to avoid boiling or extremes. The first event that got my focus WAS an over heat that caused boiling of the system, overflow etc. all for about 3-4 minutes. I shut down and had the car towed to avoid causing any damage. I started looking at everything to avoid doing this again.
I did a head leak check that came up negative…though I did this as recommended when the engine was warmed up, but not HOT. The test would be hard to perform if the coolant was at boiling temps, even dangerous. I may be doing this again soon to verify the test result.
I have not retimed the engine since static timing because of the other issues that have popped up, including all four carbs overflowing from float bowl valves. I ended up doing all four and resetting levels, which seemed to cure the problem. ( I am very suspicious of the work done by prior mechanics. Evidence suggests that they had NO Jaguar experience and were very sloppy. Every item I have found where there is evidence of some work, resulted in my having to redo work again to correct errors.)
What will be left? Tear off the pump to see if it is somehow not performing? I have replaced all hoses around the radiator. ( yes they were wrong and jerry rigged). Attempt flow checks through the heads while installed? Next, pull the engine and tear down, just to see what is going on? Maybe. It will be sad as the thing runs great at start through normal temps.
Finally, it does have the new distributor and ignition upgrade from the Opus.New radiator and fans. And the fuel system including tank were replaced.
