Hi guys see attached photo of the cable from the cruise control, completely forgot where the blue connector plugs in to?? What about the bayonet connector?? any clues??
The blue connector goes to the dump valve. The dump valve is mounted to a bracket which is then fitted under one of the cam cover bolts, RH side, all the way forward.
The other connector should mate to a jumper harness which is then mated to wiring from the cabin
DD
Thank you Doug, great info, have no idea where the jumper harness or the valve has gone but I’ve found suitable replacements. Thank you once again for your help
