You can test externally for a leak before eventually attending to it, Danny - only need a vacuum gauge…
Locate the vacuum reservoir, rear in the engine compartment - a flattened round tin with one vacuum hose. Connect gauge to the hose and run the engine - it should read manifold vacuum. Stop engine and watch the gauge - it should stay at manifold vacuum. If not there is a leak…
To locate a leak further; clamping of engine bay vacuum hoses is used. Follow the hose from the vacuum reservoir to a T- connection; one hose on the goes into the cabin through the firewall. One hose goes to a one-way valve, then down to the vacuum supply at the engine.
Again run the engine, reading manifold vacuum at the reservoir hose, then clamp the ‘cabin’ hose and stop the engine - vacuum should be retained. If leaking, the one-way valve has failed - no great matter.
Unclamp ‘cabin’ hose, run the engine and clamp the hose between the one-way hose and the ‘T’ - stop engine. If leaking; the leak is inside the cabin - indeed requiring inside access. To be addressed later at your pleasure…
Two points to make; one is that the centre vents are held open by vacuum - a vacuum leak cannot hold them open. Second; cabin temps are controlled by the temp selector, which is a potentiometer, between 65 and 85F.
However, while cabin is warming up, the system deliver max heating; there are no adjustments to increase this heating - it restricted by heater capacity and coolant temps. When the set temp is reached, the system mixes cool air from the outside and/or AC evaporator with hot air from the heater core to maintain cabin temp - in ‘auto’; fan speed drops to signal the system has gone into ‘blend’…
It’s ‘unfair’ to the system to relay on your feeling of heat or cold; a thermometer, placed near the cabin’s in-car sensor to evaluate system performance.
The point is that the temp control should adequately regulate cabin temp to your liking - and your lack of control indicates a problem that should not be solved by potensiometer adjustments. Without the compressor, the system should heat perfectly - only cooling is restricted in this situation; it has to rely on outside air temps…
Frank
xj6 85 Sov Europe (UK/NZ)
