Have a really annoying problem with my s type.When left overnight I have no servo assistance on brakes for about 5mins.After that its works faultlessly all day even if I leave for 10 hrs or more.
The car has been to the garage several times and they have not been able to find the problem.
All vacuum hoses have been checked and the non return valve to the servo has been replaced.
How come it loses vacuum when left overnight but can be left all day withoiut losing vacuum.
Could it be that the servo has a fault but if so why does it work perfectly all day,
Any advice is solving would be appreciated
Sounds like an internal valve is ‘sticky’.
You don’t offer a MY or engine size for your car. There are also optional braking systems for the different S-Types. (ABS/TC or DSC)
Some vacuum boosters have a wire harness to the booster so you need to be very specific when diagnosing or ordering parts.
Hi
thanks for your reply.
Car is 2496cc v6 se petrol automatic and has abs
when you say poss sticky valve would this be inside servo?
If I had servo taken off for inspection would it be possible to test?
Many bhanks
There are valves INSIDE the brake booster assy.
It might be cheaper to find a salvage yard replacement than to disassemble and repair the one you have?
