What is the correct procedure for installing engine studs in a short stud engine? I have previously tightened them until no further movement. My memory tells me I read on this forum just to hand tighten?
Best regards
Phil D
Best regards
Phil D
I would use NoSeez, then just snug them in with a pliers, making sure to not mar them.
I was hoping you would respond Paul. What you have recommended is what I have done in the past. I’m sure I read somewhere that they should be left finger tight but no reason was given so I wanted to check
Did a search for “noseez” out of curiosity…can’t find anywhere?
Codename?
Thanks
NevrSieze, Coppaslip.
What Drew said!
Any good brand anti-seize compound will work.
Oh, gotcha
Thought I stumbled upon some secret goop I’d never heard of…
Thanks much.
Have a good evening
(Yes, I know my reply is more than 2 years old.)
Just a quick note to say I was reaching this point in my engine rebuild and I knew if I searched the forum someone else would have been there/asked that.
These forums are such a wealth of knowledge. Keep up the good work everyone!
