Seeking a replacement distributor cap for a Mark IV . Part number is 407279
any ideas for sources?
Thanks
Lou C
Contact Distributor Doctor http://www.distributordoctor.com/distributor_caps.htm
Also Advanced Distributors http://advanceddistributors.com/wordpress1/
Also KIP Motor Company http://www.antiquedistributorcaps.com/distcaps.htm
British Vacuum Unit might know https://www.britishvacuumunit.com/
They can be found in auctions such as eBay.
Quality of product is variable. Some newer caps have tracking issues when warm. Some old original caps have continuity problems in center screw due to corrosion from just getting old (this corrosion can be sanded away from screwpoint).
This remind em that someone was asking about a distributor cap fr an SS100 DUH6A dis a little while ago. I notice one for sale on ebay UK last night .
Mark V and early XK120 have 415708 listed in their catalogues, which is also a horizontal or side entry cap. Is it the same or close enough?
For XK120 side entry caps you could try Bill Tracy in Florida, or XKs Unlimited in California.
Recently I came across an unexplained anomaly in caps.
Three caps, all oriented the same with their side clips, but one has the coil input at a different angle. So be sure to orient your plug wires according to the side clips, and not according to the coil wire.
Hi Lou.
Little bit late answer.
I found a good quality new cap for my ’47 MK IV distributor (DXH6A) at the Distributor Doctor in Wiveliscombe, GB
Best regards from Germany
Detlef
We purchased 2 from Kip Motor company in Dallas Texas.
These were very brittle. One dropped on the floor and shattered.
The other is working fine. Part # is 407279.
Price was $119.19 each.
Thanks,
Lou
I cannot even imagine the color of the air, around your head, at that moment…
