I have found that my alternator starts dying as it heats up. First thought is to check the regulator. No problem there. As a matter of fact, as the alternator dies with heat, I can see that the regulator is gradually pulling the negative field closer and closer to ground in an effort to boost the output until finally the field is seeing full current but the alternator output seems to be dying off; that is, the voltage drifts down to be the same as the battery.
I have also done the alternator test as shown in the manual with the regulator disconnected and a short from the field negative to ground. Cold, it passes with flying colors. Hot, it fails miserably.
I could not find any flakey connections when disassembling the alternator. All the diodes check out OK and I have gone so far as to use a light bulb that pulls 2 amps to verify that it isnāt a lack of current from my VOM that could be giving me a false reading. I used the same light bulb to check the windings and found no problems. All in all, Iāve had this thing apart and back together again 3 times, each time making sure that the connections are all clean and tight.
With no progress, I have taken it to an alternator rebuild shop that is highly respected around here and they said that they took it apart, did some cleaning and put it back together again and after testing, said it works as it should, under a full 60 amp load. When reiterating the symptoms relating to heat, they said they really donāt have any way to test under heated conditions, but insisted that it was working perfectly and that my regulator was probably at fault. After explaining the on car test with the regulator disconnected they really had no answer as to the problem. Iāll be picking it back up tomorrow.
Unless thereās someone out there that might have a clue, Iām considering switching to a Denso alternator, which brings up another question. Does anyone have any experience with the Denso unit as sold by Terryās? As near as I can tell, itās the Denso 210-0410 thatās used in the 91 & 92 Volvo 740 and is rated at 80 amps. The only issue I can see is that it is used in the Volvo rotating Clockwise as opposed to the SIII application where it rotates Counter Clockwise. Is the fan bi-directional in these as it is on the Butec?
There are other vendors out there selling similar Denso alternators as a drop in replacement for the Butec, and in the process eliminating itās regulator, however, I havenāt been able to tell which Denso model it is that they are selling.
Suggestions welcome.
PS During all this I have been able to document the newer style Butec regulator. Pics attached.
