I’m still tracking down some hard to find parts (rare or expen$ive, or both) for the restoration of my Series III.
Me and at least one other lister are stymied in our search of the subject items.
Question 1: I have connecting rod bolts and nuts I kept from an engine rebuild I did in 1986/87. Can theses be safely reused? i.e.: are they torque to yield (one time use) or good for another go?
Question 2: I did find some a few years back but I received a mixed batch. These (photo immediately below) are known to be correct, they are Con Rod Bolt C33271 for 5.3 V12 models up to 1975 and are what I know I need:
I have come to understand these are Con Rod Bolt C43809 for 5.3 and 6.0 V12 models from 1975 onwards. These are significantly shorter as the photo below shows.
So (finally), question 2 (which I suspect I know the answer to) is: Can these “New Inventory” bolts safely be used in a 1972 Series XKE V12 engine?
Question 3: Anyone know of a vendor selling the Con Rod Bolt C33271 for 5.3 V12 models up to 1975. I’ll need 24 nuts as well.
They gotta be available out there – restoration shops are still working on V12s, aren’t they? The answer is out there – thanks in advance for helping me find it.
I have never seen them, but my concern would be the different lengths. That means different rods to me. For Chevy 454 LS7 rods you could get knurled shank and ground shank rod bolts. The ground shank were more accurate and expensive.
Agree on ARP nuts. Ford or Chev had variations from 11/32" to 7/16"
I had the same confusion. After playing around on the SC site – expecting them to follow through on their intent to reproduce the bolts – I finally found it/them. Now – why would they go to the expense of reproducing them and then NOT use the Jaguar part Number??
After I pulled myself up off the floor and caught my breath, I tallied the damages. Since I have 10 new connecting rod bolts I only needed 14 more. But needed all 24 nuts
I attended the Hot Rod Nationals in Pueblo on Sat 26JUN21 and traveled with a friend. We were discussing my engine rebuild on the way and he rekindled an old memory. I rebuild the engine in 1987 to cure several oil leaks and 2 exhaust leaks. Connecting rod bolts were available them – and I replaced them all. Now – while that was 34 years ago, I only drove the Jag for 2 years before taking it off the road for a re-paint (and here we are decades later). I don’t remember my mileage in those 2 years but 12,000-15,000 seems reasonable.
Q: Am I worrying about a whole lot of nothing?? {I realize using 24 new bolts/nuts is ideal, but $450!!!}
Dominik – I wish I could agree with you, but the car’s not-so-recent history is pushing me in a different direction.
My Jag last ran under its own power in 1991 or 1992.
From1990-1993 my Jaguar was stripped to bare metal, all body work done, and primer-ed – no paint.
From 1993 to 2008 it sat in a non-temperature controlled storage garage in Phoenix. HOT and DRY
From 2008 to 2021 it sat in a non-temperature controlled storage garage in Colorado Springs. WARM and DRY.
That’s 18 years in Phoenix
That’s 13 years in C Springs
Total = 31 years
If I were to try to start the Jag, it may start but I suspect it would leak from every seal, gasket, hose and/or orifice – I’d have a rainbow of fluids under the car. And while – so far – I have not found any evidence of chewed/gnawed/damaged/destroyed wires, I have plenty of evidence of rodents being in residence.
Hence the total tear own and rebuild. It’s all good fun – – I learn something new everyday I’m out there.
