After a significant relocation, and 6 months in the garage, I’ve gotten my 85 Series III barn find out and started driving it again. It sat idle in the garage because the climate control system was stuck in full cold mode. Not too nice in the winter! Finally got that repaired thanks to Gary Crosby and a rebuilt Servo Motor. Now I am chasing several other problems.
The idle is doing two things that I don’t like:
a. When the engine is cold it tends to bog and die when you try to accelerate from a dead stop. Rather embarrassing at stop lights. Based on the FAQ article, I have started diagnostics on the Aux Air Valve and after removing the hose, find its little valve is closed when the engine is hot. Have not checked when cold yet. Will try and do that in the morning. Anything else that could be affecting this?
b. The idle sits at 1,000 rpm in Park but drops to around 500 rpm when the transmission is put into gear, and then adjust up to 750 rpm. I can adjust the idle high using the allen screw but when put into gear it always settles back to 750 rpm so it seems to be controlled by something else. Is there anyway to tweak the idle speed while it’s in gear?
Matt Grimes
Back in Colorado Springs, CO
1985 Series III (Barn Find)
