I am about to change out the right front wheel hub, and reading the manual I need a special tool 204-293 to split the ball joint.
I can find it online, costs about £155/$220. I have looked at more generic ball joint splitters, but they all seem a bit too small.
Does anyone know a tool that works but isn’t that steep in price, or if soḿeone has the tool, if I could ask for some measurements?
Don’t know if it’s done where you live, but here, in USA, some of the above parts retail stores rent the tool set, which contains different shapes and sizes, for a very low costs - some even have a “loaner” program for the cost of the set, then you are refunded all your money on return - think it is a marketing plan to hopefully have you purchase the new parts - such as the ball joints, from them.
Simple scissor ball joint separator always worked for me. A little touch up with grinder may be needed to clear larger rubber boots but that is a one time only mod.
Removing the upper ball joint was jolly good fun, it went as expected, not too hard, not too difficult. The kit had the proper stuff in it.
The lower ball joint was a lot of work. The kit didn’t have a good size tube for the job. I used the largest one, and damaged it in the process. I used a 2 foot breaker bar and pulled as much torque on it as I could muster. To no avail.
Took the tool away, heated it up with a butane torch. Tried knocking it out with a hammer. No give.
So, heated it up again, assembled the tool around the ball joint. Put as much torque on it as I could, and then some. Then started tapping the bolt. Suddenly it gave way with a snap. Same procedure again, torquing and tapping, again it snapped. Then I could wrench it out with a regular ratchet. I am glad I got it out, and visual inspection shows no damage done to the lower arm.
I put so much torque I actually bent the C clamp a bit out of shape. Not much, but I can’t put the screw back from the “opposite direction”. It won’t thread back into the hole from that direction.
To summarize - You might need more force than expected
So, now I just need to buy a tool kit to do the installation.
