Restoring a 1955 Mk VII, I need to restore the steering wheel, took it for powder coat but, they couldn’t sandblast the hub and rim as it has a “rubber coating”! Probably needs chemical stripping? Suggestions?
The wheel is plastic coated . This has to be removed, and the easiest way to do it is with a blowlamp, scraper and wire brush. . CAUTION, however, this must be done out of doors as the plastic tends to catch fire
Thanks, already found out the hard way! Outdoors is essential!! But if you let it burn the scraping is easy then sandblast and re-coat.
