Good evening everyone have a weird one that I am totally baffled by
1995 4ltr sovereign regular sound system
When I play radio sound is perfect, when I listen through the tape cassette also perfect all speakers working perfectly, here’s the weird part if I play from the 6 cd changer located in the boot the front passenger speaker sounds terrible has anyone had this problem, any help please
Get the wiring diagram, and find the wire at the 6CD changer in the trunk that carries that signal and then pull the radio out. Run a separate, new wire from the CD changer to the back of the radio and see if that fixes it. If it does, it’s a wiring problem, which can be fixed by you.
If it doesn’t, it’s either a CD changer issue or a head unit issue. Unlikely to be repairable. You might have to take a 50/50 shot at which to replace first to fix the problem.
