Was surfing today and came across a thread on another site. The folks were really impressed with this “stodard bracket” for the AJ6 4.0 engine. It advances the timing by 5 degrees and supposedly gives better performance and mpg.
I did a search here but it came up empty. Any of you folks have first hand experience with this tweak? I’m not concerned about the mpg (it is a Jag after all) but the increased performance sounds intriguing.
It’s not like it transforms your life, mind you. But there IS a palpable improvement in throttle response; snappier in mid-RPM, mid-throttle situations
There are some articles on the net about it…one said it cost about 75 pounds uk…on xjr it increased mileage a little…advances crank sensor 5 degrees…kind of reminds me of the model a ford i had as a kid…had manual advance on column…
I just finished ordering it. I’m starting a coolant hose/radiator refresh so I’m thinking it should be very easy to swap once the front bit of engine is opened up.
