lovely β¦ thanks for good information. i am going to do similar on rough 140 - did you decide on 4.2 rather than 3.8 intake because of breathing or plumbing water?
Interesting set up, no I have no problem with the hisser when set up properly, I will be leaving it on the βSβ when I finally get the engine back in. I just flick the ignition off and on quickly when I feel the engine will run well without the need of the choke. The AED, well thats another kettle of fish
Ingenious Peter. I have no problem with the SC either.
With best regards
Philip Dobson
that is art & engineering together, thanks for the pics,
very interesting to see a different approach
the reason I eliminated the ASC/AED for a manual choke
ever present fuel smell from ASC drillings is gone
(in my case) 90% of trips ~10min, choke is better for this
I am curious your dislike of lowering jets, other than a possibilty of non-accurate return to set position ?
Yes John the more even flow from the head., although whatever possesed Jaguar to place the linkage under the manifold rather than on top as the 3.8.
Exackly this Tonyβ¦
Peter B
Money and beauty, I assume. After the tooling investment making the one-piece part id far more secure (no leaks) and cheap than the five-piece part it replaces. Plus the head no longer needs two waterways machined/plugged.
Aesthetics (acres of polished alloy) and tidy appearance will also have trumped linkage accessibility (which is still OK, just not quite as easy).
Yes Peter but the E Type and MK10 were allready geared up for the top moubted linkage.
Does not the visible linkage have aesthetic appeal, or is this just for old grease
monkeys like -
Yours Truly ,
P Balls
