Driving along and engine suddenly ran really rough. No vacuum on front carb. Back carb is fine. Timing ok. 6 cylinder compression even and good.
Can not find an air leak anywhere (that does not mean there is not one)
Why would one carb have vacuum and the other basically none? Are they completely independent?
Any suggestions greatly appreciated. Totally frustated.
I rebuilt both carbs a month ago so anything is possible! Checked and linkage is tight. Car starts easily and idles smooth but collapses when I increase the revs.
I have seen this occur when a needle is slightly loose in the dash pot piston. Worthwhile just checking the needle security on the problem carburettor.
I have the filter off. Took the needle out of the dash pot and reinserted it. A friend with a 140 came over this morning and we tinkered some more and suddenly everything fell into place and the darn car ran smoothly. Took it for a test drive and no problems so far.
I guess we will never know what caused the problem in the first place, but as they say “all is well that ends well”
Thanks for your suggestions. The float. is new and I had it out last week …no leaks. Pistons were rattling, but now that the engine runs smoothly nothing irregular.
