Through the water pump / thermostat cooling system rebuild, past the Distributor rebuild (unplanned), now on to the carb hopefully adjustments (also unplanned!) one day maybe I’ll get to drive this car!
I found that after servicing the distributor the car seemed to be running rich, ie almost stalling when the throttle is first blipped once warmed up, and the plugs looking very black very quickly. She also has a bit of a lumpy idle.
So I figured a quick carb adjustment was called for.
The rear carb seems pretty good - clean, nice drop to the piston, found the jet adjustment screw to be 2 turns out which seems like it might actually be a bit lean as I believe the starting point is 2.5 turns?
The front carb is a bit of a mystery… slightly different looking piston which set of some alarms in my head, and not a sharp drop to the bridge. My plan was to try and recenter the jet on this carb, and then set idle and mixture on both and see where that got me against my stalling / stuttering issue.
So i was surprised to find that the font carb does not have the cap on the bottom of the jet adjuster. Anyways, not sure how long it has been missing, but I decided to proceed with my plan and order up a new Cap to install as some point in the hopefully not to distant future, in the meantime I was hoping that I could still adjust the carbs and drive the car without this piece.
I proceeded to screw the jet adjusting screw up to see how many turns it was currently set at vs the front one at 2. But it seems that the Nut that secures the jet assembly is turning as well and after many many turns I am failing to understand the relationship of the jet assembly parts… I’d like to have a sense of what the assembly procedure is for these parts so I can understand how to correctly set them up from here… I have not taken these parts out of the carb body and would prefer not to - the carbs are still on the engine and if I proceed much further then I guess I’m looking at doing a complete rebuild - not really what I wanted to do right now although I can see it coming maybe this winter.
So has anyone got reassembly instructions for the jet assembly on the H6 that would help me understand how to adjust jet bearing and securing nut,
and also, is it OK to drive the car without the Cap on the bottom of the jet adjuster screw? interesting that when I pulled this cap off the rear carb it was full of gas - if that’s normal then the front carb should be leaking without its cap, but I haven’t noticed any gas leaks… one of the first things I checked for when I first took on this car!
Cheers,
