I took my baby out for a ride last weekend but had to break off because the turn ibndicators did not work!!
I read a lot and heated up the garage. Hazards worked but no turn indication. The system is a bit complicated but after measuring through I determined that there was no power for the indicators going through the Hazard switch. Thinking that I would have to find a new one, I took it apart, cleaned the old hardened grease from the contacts, bent some more tension in the contacts, lubricated and put it back together. Magic. Everything works like new!!
Good that there is so much information on the forum, thank you.
Barry
XJS, X-Type, Daimler 250 & XK150
Thank you for sharing.
This will undoubtedly help many others in the future!
