Sucking sound from engine when warm engine restarted
Summary: warm engine re-start attempts results in violent sucking sound from fuel tank area
After driving the the XJ8(1999 with 45,000 miles) for 10 to 15 miles, then parking it and tuning off the engine for 30 minutes or more, an attempted restart results in a violent sucking sounds and rattling sounds (similar to the sound a straw make when you are trying to get the last of a soda out of a cup). It will then not start or idle like a cold engine, but instead it requires pumping of the accelerator pedal to get it going again and only after several attempts.
When starting the car a few days later, it started cold and without the noises. Considerable gas fumes are occasionally present. I am guessing the noise is the fuel pump trying to pump fuel up to the engine but having trouble doing it. Or, could this be a vapor or injector issue? I just don’t know. Any help will be much appreciated.
The next time you are doing a warm start, try it with the gas filler cap off. If that improves it, then your problem is with the gas tank vent.
Please post to the correct area of the forum. This the the XK not XJ.
bob
That may have been a typo. When you look at both of Roger’s posts, the other one says XK8.
Note: in the first sentence of my post, I mistakenly identified the car as an XJ8. It is, of course, an XK8. Sorry for any confusion! Thank you!
