Good afternoon. Let me provide something to think on while we are all confined.
Last fall, my '62 3.8 OTS started to run unusually warm on an afternoon drive. Like all, I am always keeping an eye on the temperature gauge. Where it typically ran 70-72 under almost all circumstances, it was starting to go to 90-95 after sitting in a little traffic, and very reluctant to cool down once under way. Only after 10-15 minutes of open 60 mph running would it get back to 90 and stay there until parked.
Once again, this came on suddenly. The only remotely possible action I took before this occurred was replacing of the somewhat crusty header tank with a new Stainless Steel copy from Welsh. I can’t say that the problem started immediately after as I don’t remember. In any event, I doubt the tank is at issue.
Actions taken last fall and the last two weeks;
Tested and replaced Otter switch, tested and replaced temperature sender, replaced gauge (unnecessary), installed Coolcat adjustable voltage stabilizer for gauge and calibrated with IR thermometer on black tape next to sending unit, tested 15 year correct Robertshaw sleeve thermostat (OK), redid upper and lower radiator hoses (soft), replaced water pump belt, flushed cooling system with Thermocure, then sufamic acid, then neutralized with sodium carbonate (I can see the fins and tubes in my 15 year old Howe aluminum radiator and they’re spotless), I’ve fattened up the mixture to no effect, run without thermostat without effect, coolant moving through head quickly when revving indicating water pump functional. Mallory dual point 8 BTDC at idle and 32 degrees all in at 2800 rpm confirmed. No visible leaks, 10 lb cap on overflow tank. Temps checked at all points with IR, radiator discharge 15 degrees less than intake.
Motor back round; rebuilt 15,000 miles ago (by me w/exception of head work done by the late John Miller at Straight Six Jaguar). 8:1 pistons with more aggressive cams. Engine has and continues to run fabulously with broad torque up to the red line.
Most importantly, I’ve been working on this problem for the last two weeks while the temperatures have been in the low 50’s here in Virginia. I fear the impact of summer temperatures on this problem.
Thank you in advance for any assistance rendered.
Cheers.
