Well I’ve got a nagging O2 sensor code, and it’s the pre catalytic or upstream sensor, I figured I might as well replace all of them while I was at it.
This seems to be pretty straight forward, space is a bit cramped; but that’s nothing new to Jaguar engine bays.
Is there anything I should be aware of before I head down my merry way?
Good point! I will keep that in mind when that time comes. Probably sooner rather than later like I thought. My work will be curtailed for at last May 18th due to the whole Corona Virus thing.
this will give me a chance to catch up on my YouTube channel as well as other Jag Related projects I’ve got going on.
My codes went off a couple of years ago. My local Jag mechanics said that they always use NTK sensors. After buying some cheaper units that did not cure the codes, I got the NTK and everything cleared !
One of the easier jobs.
Thank you Louie, I have a small fortune tied up in the NTK sensors. Good to know – I seriously thought about getting a cheaper sensor, but I’ve used NTK in the past and they’ve worked like a champ!
