Can anyone help with the connections for a Xj tach? I assume one is direct to +ve and the other to the distributor side of the coil?
I have nothing for the XJ but the S3 wiring has a green wire (hot) that passes through the tach then goes to the ballast resistor via a white/blue wire.
pauls
Just wondered which pin is which?
Can’t help you with that. Someone on the XJ forums can probably help, you definitely need precise instructions.
pauls
Many thanks David…
