Hello together
I have a problem with my tandem master brake cylinder. There was a wrong one installed. I have an old, original bought in the net and try to refurbish them. All parts are in a usable condition. Only the piston stop No. 4192 is corroded. I had to press them out. Now my question! Does anyone know where I can buy one? Or do I have to make the piece by myself?
Second question! Does the piston stop have to be tight in the housing or must by slidable? If I build up pressure it would completely compress the thin spring on the left if the piston stop can slide. What is correct?
Translated with DeepL Translate: The world's most accurate translator (free version)
Bremszylinder.pdf (150.1 KB)
