I am finishing rebuilding the engine head on my 1989 XJ6 (burned valve made me do it), and I wonder if I should go for Teflon/silicone valve stem seals, instead of rubber ones that come in the head gasket kit.
Anyone has experience or knows Teflon/silicone seals that fit AJ6 engine with standard cams? This is not necessarily the correct fit, but as an illustration of what I am looking at: Teflon valve stem seal
Also, I read somewhere that original rubber seals do not grip tightly on the valve stem, and there is always a bit of oil flow down the stem; Teflon ones, on the other hand, grip the valve stem tightly, so would that be a stem/guide lubrication issue?
