Keep looking at those diagrams until you understand why there are no rear brakes if the pump isn’t running. Only the front brakes can be “manually” actuated by the master cylinder.
Yes Kirbert, that’s constructive…
I will keep on looking as so far it looks like you will have rear circuit until pressure in accumulator is depleted (isn’t that the reason why it’s there? also know as design safety factor…)
So, if the front brake hose bursts and the brake accumulator assembly doesn’t work (pump isn’t running) - then you have no brakes.
Quite unusual scenario in the brake system which is not totally neglected by pensioner or stereotypes…
Definitely, this device is soo dangerous - it must be removed, once and for all
If the front brake hose bursts and the brake accumulator is still working fine, you have no brakes. You must have front brakes to have rear brakes.
Kirbert,
You don’t know or trying to patronise?
The movement of booster piston is LIMITED, it won’t drop all the way in.
Now as description goes both circuits are not mixing fluid with each other.
Also, it is funny that brake accumulators are srill being used in critical safety systems, more in aerospace…
Just asking, does the action of a front brake hose bursting deplete the accumulator hence no pressure remaining to drive the rear brakes?
On the drawings and from description - it looks like accumulator pressure is retained in rear circuit only, there are seals between both pistons isolating it from each other.
Booster piston can apply few milimeters of pressure on the back of master piston to support operation of front brakes, it cannot drop any further forward.
So, no - it doesn’t look like burst of front brake hose would drain the accumulator. It would cause loss of pressure in accumulator and would trigger pump operation (pump fed from separate section of the tank)
Now.it is time to wait for Kirbert and his keen eye for details to confirm/deny it
I am told that the Teves MK 111 unit on an XJ6 is almost identical to that on the XJS and in the case of sticking solenoids (my problem!) you can use the ABS block and replace the cover plate with old one as the plates are a slightly different thickness.
Rich,
The ATE mk3 was used in many cars, including Ferrari and Volvo. The solenoid issue simply requires replacement solenoid. These may be adopted from any model, some of these however - works other way around and will require simple relay to function.
Prior to replacing “sticky” solenoid - make sure it’s actually the issue - never heard about stickness before, issues with accumulator sphere or air in the system may give you “sticky” response I assume…
Hi Janusz - There was no fluid coming out of the one leg of the ABS block and when the solenoids were checked, one of the six simply hummed, others clicked, so seems v likely that the solenoid is stuck - it is not open circuit.
Rich, can you describe how the solenoids were checked???
