[quote=“MarekH, post:10, topic:430245, full:true”]
I disagree with almost all of this… and here’s why.
We all have our opinions, Marek…
My opinion is that temp variations due to heat is unsuitable. My opinion is that we want as much spark energy as possible - voltage bridge the plug gaps, energy ignites the fuel. Restrictions are a result of components having resistances, which limits current flow and cause heating - which must be controlled, not the other wy around.
The heating of primary and secondary coil wires is not instantaneous, nor does frozen peas applied externally cool the coil wires instantaneously - it takes time. I don’t share the idea that ignition will not work properly without the use of heat variable resistance - though of course, resistances are unavoidable…
In principle; the influence of heat on resistance variations are easily done as you outlined in a previous post;
Connect coil neg to ground via an ammeter and turn ign ‘on’ - read current. Initially current should be as defined by coil (and eventual external resistor) resistance - then the influence of heat is shown by drop in current. And, additionally, overall hot resistance can be easily as a back-up. Of course, the coil will quickly heat up - so circumspection is called for.
The same test can of course be carried out on any resistor - the ‘ballast’ resistor (like ballast in a boat) is called that because it generally lowers current flow, not because its resistance value varies. Essentially, digital ohmmeters can easily detect resistance within 0,1 ohms - which is why injector coil resistance can be checked to the correct 2,4 ohms.
Current is only flowing through the coil while the coil neg is grounded (points or amp) - as soon as ground is broken the coil ‘rests’ (cools/not heats) though spark energy is released through the secondary winding. So main heating occurs during coil grounding - which varies with rpms, but increases in frequency as rpms increase.
Ideally, the coil should only be grounded for the time required to fully charge the coil - which, crudely, is constant as per a constant dwell angle. In idle the grounding is longer than necessary, creating unnecessary heat. The Lucas CE system somewhat counters this by varying the dwell angle with rpms - but it is still fairly primitive…
Unfortunately, neither of our opinions are of much help to Chris - the system is what it is whatever our respective opinions…
Frank
xj6 85 Sov Europe (UK/NZ)
