OK I live in Arizona and it gets Ferkin hot as I shall be using my RHD MKII all the time I will need A/C has anyone out there fitted one to a MKII such as Vintage air or restomod air or … What ever
AND if so pictures would be great I know its a lot to ask but I have to do it, especially IF I have to do body mods before my car is painted.
It’s been done by Vicarage in the uk. They may have some pictures. I vaguely recall seeing a write up probably in the JEC magazine. I think it was ducted do it came out on the rear parcel shelf.
Vintage air makes several trunk mounted units that should work. You would have to make brackets for what ever compressor you use, they sell sanden compressors. They also have E-Z fit hoses so you can customize the lines.
I have worked with them on several OEM projects. Good people to work with.
My father and I were very satisfied with the AC in our 1963 MKII that we had in Texas. It was dealer installed in 1963 in Houston, Texas and was very effective in Texas summers. It was trunk mounted and had two condensers, one in front of the radiator and one under the front bumper. My father owned the car from 1963 to 1976 and then I had it until 1985.
My a/c freezes us out in the 62
It looks like vintage air but the whole unit is tucked under the cowl!
Sanded compressor with nothing in the trunk!
Mine is heat and air it is a complete unit in the cowlgtjoey1314
I think I have the MOSS motors kits…its more expensive but fits in the heater box.
I works wonderful, the battery has to go in the trunk though
good luck
gtjoey1314
You might want to check with the Coventry Foundation. They hold all of the development and installation drawings and guides for the Jaguar approved AC systems developed in Texas for Jaguar.
further to what Dick mentioned, their is also a useful publication by George Camp on the JCNA website (or used to be anyway)
In my mind you have to decide whether you want cold air in the face, which is the modern unit, (including some mods) , or an original style trunk mounted unit
Its possible to make the trunk mounted unit big enough to freeze the car, not what everyone wants though.
I have a mixture of Sanden and “Universal” parts in my vehicle, but some OEM Jaguar pulleys and brackets, which look good
Once again thank you all for you responses I checked around and must admit I found the original one kind of obtrusive and have decided to go for the one that XKS Unlimited have as it will suite my needs best and at $2500 it’s not a bad price
Hi, I am new to the Mark 2 world, but I understand that ANY Mark 2 with AC is going to overheat if the outside temp is more than 80F? Is that correct? Any way to stop that?
It would be aftermarket but the questikn might be “is there a condensor/ radiator confugurstion thst can cope with hot climates?” I have seen some mention of a condensor under the bumper. Cheers
Yes there must be a condenser somewhere, as I live in Arizona and will be installing an aftermarket A/C system
that I am going to buy from Moss Motors I checked it out and it has an upgraded fan to get better airflow,
I also will be installing an electric fan at the front.
I have a modern vintage air type system in my MkII, new style Sanden compressor, fan up front on condensor, but if over about 85 degrees or so outside temp it really does not stay very cool. Only have two vents in dash below center inst panel, just not enough volume to cool much better.
John
In the 1960’s, in Houston, we had the trunk mounted unit that put out a lot of cold air. The system also had the two condensers. One thing my father had done was to re-core the radiator and increase its size and I don’t recall any overheating issues.
