Hi guys,
an 89’ US version of a 5L V12 engine got caught on fire that was extinguished fairly quickly because it happened close to a movie making stage in downtown Budapest, but it seems like it wasn’t quick enough, the engine cable harness suffered major damage for start.
see some pictures here:
http://pumi.org/geza/temp/browseable/89-Jag-XJS-V12-USA/
They seem to be quite boring since everything is all white.
My friend tried to figure out what could have caused the fire and when he gave 12V to the fuel pump, he noticed that fuel was coming out from the vacuum controlled fuel pressure regulator, so it looks and “smells” like that this puppy was the guilty one.
For start, what do you guys suggest, how should we clean the extinguisher dust off the engine with the least amount damage? What I mean is, how sensitive a V12 engine to steam cleaner:? Because that’s what we would use as a first idea but I was thinking maybe we would just add more problems to the unknown existing ones since the steam vapor could get into any harness and just give more puzzles for us that to be honest, we don’t need right now.
And for the 2nd step, we’d like to replace the engine harness but we’re not familiar with this engine on this level, the question is: how many harnesses are we talking about here? One huge octopus, or each side has it’s own? Where is or are the junction connectors, in the engine compartment or somewhere under the dashboard?
And generally speaking, what do you guys suggest how should we proceed to fix this engine the most efficient way timewise?
We already know that we will have purchase the engine harness(es), fuel pressure regulator, and most likely the ignition modul, that sits on the top of the engine (what a weird place to put that by engineers!) since it must have gotten a lot of heat. And whatever we find damaged after the clean up, then we will have to order the parts from somewhere, install them and try to start the engine and then go from there, order the second batch of parts. This is my idea of a possible work flow plan, but I could be wrong.
Geza
