Let s not forget that the series 1 out of the box was a 150mph car back then. I don’t think anybody complained about it feeling light over 80 or even 100 mph.
I also seriously doubt Norman Dewis would have allowed the E-type to feel floaty at pretty much any speed even though handling standards were a little looser back then
Again check the suspension and steering and then tweak the height
All I can add is that a stock E-Type should feel rock solid up into triple digits, and this should be true even on less than smooth road surfaces. A good set of shocks and replacing the suspension bushings may go a long way here.
I dunno - I drove my race car (a coupe) at 145 mph routinely, in all kinds of conditions, read high winds in particular, and it never felt uneasy, unsafe or too light on it’s feet. Just saying this because I think it’s possible to overestimate the effect of lift at speed. The stock suspension on an E Type is too soft for speeds like this, in particular if you are not used to it. The suspension needs to move much faster (and will move further ) at speed, and in stock form will over react to imperfections in the road causing a feeling of instability. We used much harder suspensions racing which at high speed feel like a stock suspension feels at low speeds - it seems to soften up - so much additional energy going into it.
I have a late production '71 series II OTS. I can readily do 80 - 90 with very solid footing. Standard suspension set-up with modern tires. I have gone north of 100 mph but not for long duration.
I agree. once I replaced my 20 year old Michelins my mostly original suspension 69 S2 hits 80+ with ease. I may have cracked 90 a time or two, but the biggest limiting factor for me is that I have original gearing, including the 3.54 rear end, so for me the motor is getting a bit wound up to spend a lot of time that fast. besides. I would never condone exceeding the speed limit!!
Well… we can agree to disagree. I’ve driven a few cars in excess of 120 MPH, and the E was the first one to make me say “Whoooa, easy” when I hit only 120 on a test drive.
Adding that very small spoiler under the bonnet makes a tremendous difference. I prefer to feel the front end firmly on the ground at that speed.
LLoyd
“Prediction is very difficult, especially if it’s about the future.”
The original post indicated the car started to feel unstable at 70-75, and stated, “[I’m] definitely not feeling like I’m going to see the high side of 80 for quite some time.” My comments were in regard to that, not taking the car to its upper limits. I rarely take the car much over 100, and then not for long, but it always feels planted.
On a recent trip I hit 95 and no signs of looseness. An S3 mind you with a V12 in front.
BTW, My understanding is that the V12 all aluminum engine weighs about the same as the iron block XK engine ?
In another thread, the esteemed Mr. Dick Maury said something to the effect: “If you haven’t driven a E with a proper wheel alignment, you haven’t experienced the car to its fullest”.
I think I’ll work towards covering that basic. Now how to get the E to (and thru) Atlanta and to CW is the next challenge.
