44000 miles, everything seems to work as it should. What do I need to look out for? Any common issues? I don’t know too much about this model, so i’m not sure if I should go for it, or run like hell. Your expert opinions are welcome. Thanks!
-Gus
If you use the search function or just scroll through most of the posts in this forum, you should easily be able to find the common issues. I believe they had fixed the dashboard issue by 2016 and begun using staples. Not sure about the delaminating windshield issue. I can’t imagine there would be many issues on such a low mileage example.
