This will keep me busy for a few weeks :-)
(Ian) #1
:grinning:
(Phil.Dobson) #2
hmmmm. what’s the plan?
(Paul M. Novak) #3
A little Simple Green and some new brake pads and you’ll be ready to reinstall them?
(Ian) #4
They have never been on a Jag , so not that simple Paul :neutral_face:
Plan is to clean them up , get the pistons out , strip them down , clean them up , drill some holes , paint them !
I have a old hub , so can trial fit them , sort some back calipers out !
Then when the Jag goes for a MOT Oct , will get them to do a brake reading print out , then change the calipers over do another brake test ,and see if it was all worth it :grin:
It’s cold and wet in the UK , so it gets me out and stops me watching TV , plus I enjoy doing such things :wrench::nut_and_bolt::gear::clamp:
(Andrew Waugh) #5
Perhaps it’s just the angle of the photo, but that looks like a caliper for vented discs. How wide is the gap?
Unless the parking brake mechanism mountings are hidden in that pic, you won’t be fitting it to the rear.
(Ian) #6
I did ask the question before he took them off the car , he said solid disc , it is a front caliper , I did say sort some back calipers out , ie , use front pistons , or xjs or series 3 xj6 !
(Ian) #7
S@*T , your right Andrew , they are for vented discs , just text the guy , he is giving me a full refund , they was only £30 , too good to be true , unless I can fit the vented discs to ?
(Andrew Waugh) #8
You can either fit vented disks, or if they are the early calipers you can split them, remove the spacers, fit new square o-rings and shorter bolts.
Then you can sell the spacers to someone wanting to upgrade to vented.
(Ian) #9
I guess the vented disks are not just a bolt on job ?
(Andrew Waugh) #10
I’m not sure about your car. I think your uprights have a smaller lug spacing for the Dunlop caliper mounts.
I looked at it for my S-Type, iirc it was a straightforward swap of the discs to the XJ vented.
£30 sounds pretty cheap for a set of rebuildable cores. I’d hang on to them - even if they won’t fit your uprights, you could keep an eye out for a set of uprights…
EDIT: The Brembo online catalog lets you search for discs by dimension, so it should be easy to check if you can get vented discs which will fit your hub.
(Ian) #11
Well they are free now , he just refunded me the full amount !
I will have to take some sizes off the jag disc , e bay is a good place to look for discs !
There is discs with all the sizes you need , just need to find the right one :sunglasses:
s-l500%5B3%5D
(Tigger) #12
You are all mechanically / technically well beyond me, but I fitted Wilwood 4 pot to the front on standard discs courtesy of a rather lovely bracket supplied by Team CJ.
(Ian) #13
Sold the Vented calipers , lower price set of solids turned up , winter job now !
