this yellow cable was disconnected !! On purpose ?
How should it be connected?
Have no idea what model year or engine you have.
Looks like it’s under the drivers dash?
Suggest you specify what year and what market you vehicle is. Also, unable to tell if the other end (left end in the photo) of your yellow cable is connected ? From the photo, the other end may or may not go into or underneath the fuse box. Location of the fuse box in the photo ? Which fuse box is it ?
SD Faircloth
Yes, it’s under the driver’s dashboard
1990 Jaguar xjs 5.3 V12 8S
thanks,
1990 Jaguar xjs 5.3 V12 8S,
I found it was the only yellow wire but it broke
are you sure it was in use ?
ie any symptom of missing function ?
as there’s a clip on connection (red box between the yellow connectors) someone has hacked the loom, probably to install an aftermarket alarm, probably removed / disconnected since
The work of Mr Deayewi
