How do you set the micro switch that is activated by the throttle linkage on the 82 xj6 s3?
cheers,
Andrew
So that it just clicks when the throttle is closed.
If it’s not adjusted it will either go up and down in rpm (cold, rolling downhill) or it will be jerky in stop-and-go traffic
Thanks David, that was what I thought but needed to double check.
